Hello Guest it is November 13, 2026, 03:50:58 PM
Author Topic: Backlash Use Info  (Read 9973 times)
Offline Garyv
  •  103 103
Backlash Use Info
« on: October 02, 2006, 12:50:10 PM »
I am wondering what experiances with using the backlash feature in Mach 3 that you have had ?
   I am getting ready to run a small part out finally got the code where I want it , ( lot of trial and error)
 But I desided to add my backlash comp in conf screen and It works fine manually moving X and Y, I added a comp of .005 on each that seems to work on my mill..
    But I have not run a G code with it yet .
    What I am wondering is ,
  Is the Backlash comp taking concideation of arcs and partial movements when running the code? , I'm sure it does but was wondering how it is set., I can understand a x and y movement just compinsates the .005 thou in to the return but how is it doing arcs and such?
 Just wondering
Gary V
Re: Backlash Use Info
« Reply #1 on: October 02, 2006, 10:03:40 PM »
It will correct the lash at every quadrant... You are right in thinking that arcs could be a problem :)
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
