Hello Guest it is November 13, 2026, 09:34:56 AM
Author Topic: What did I do wrong  (Read 14829 times)
What did I do wrong
« on: March 07, 2010, 06:57:42 PM »
I'm making  some PCBs on my machine, I made a few yesterday and I want to use the whole PCB. However Mach3 on the PC controlling the router is not reading the file correctly and I do not know why?
I have Mach3 installed on my main PC to test the gcode and the same file looks good.
Here is what it is supposed to look like. The blue lines are supposed to be squares.
Here is what the PC controlling the mill is producing.
Re: What did I do wrong
« Reply #1 on: March 08, 2010, 01:14:37 AM »
Can you attach the xml for both machines and also the code. You will need to rename both xmls to attach them to the forum, if you rename them PC.xml and Machine.xml that should be fine
« Reply #2 on: March 08, 2010, 08:32:51 AM »
Here you go.
« Reply #3 on: March 08, 2010, 09:29:03 AM »
Both profiles seem to be loading things fine here so afraid I dont know what to suggest if the profiles is definitely from the machine :(
« Reply #4 on: March 08, 2010, 09:31:47 AM »
hmmmm that is strange. I will try a reload of Mach3 but I just ran almost the same gcode a day before. I just moved the group over an inch?
« Reply #5 on: March 08, 2010, 09:41:57 AM »
How did you move over the inch?
« Reply #6 on: March 08, 2010, 05:19:43 PM »
I figured it out. It is the program pcb-gcode that is causing the problem. Sorry for the trouble.
Brent
« Reply #7 on: March 08, 2010, 06:06:32 PM »
No trouble, just glad you got it figured :)
