Hello
Guest
it is
November 23, 2026, 10:11:41 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
A Little Help Please.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: A Little Help Please. (Read 24335 times)
cdntoolmaker
8
on:
March 05, 2010, 02:49:25 PM »
On my Taig mill when jogging my Z axis using the up and down arrow keys the motor intermittently freezes almost like it is binding and sometimes the up goes in the minus direction. Also the Z axis will not start moving unless it is jumpstarted by hand. Does anybody have an answer for these problems or any suggestions? Just a final note about the binding. When the controller is off and no power is to the motor I can freely turn the headstock up and down using the hand crank. I am having no problems at all with X & Y axis. Please could someone help me....
Logged
Carnoustie, Scotland
Re: A Little Help Please.
Reply #1 on:
March 05, 2010, 03:03:46 PM »
Sounds like noise issues or possibly loose connections on the step and dir connections.
Logged
cdntoolmaker
8
Reply #2 on:
March 05, 2010, 04:16:21 PM »
Hi Hood,
Thanks for the responce. I can check for loose connections, but what do you mean by noise? How do I find and correct it?
cdntoolmaker
Logged
Reply #3 on:
March 05, 2010, 04:21:36 PM »
Electrical noise, basically interference on the wires. If you have any higher voltage wires running beside the step/dir wires they could cause noise in the step/dir wires and make the drive think its getting signals. Low voltage wires such as step/dir should ideally be shielded to help protect from noise.
By the sounds of it though its more like a bad connection.
Logged
Dan13
1,208
Reply #4 on:
March 06, 2010, 08:32:44 AM »
I agree with Hood. It is most probably a loose connection by your description.
Daniel
Logged
cdntoolmaker
8
Reply #5 on:
March 08, 2010, 08:34:00 AM »
Hi guys,
Thanks for the suggestions and information. Over the weekend I went through each connection and everything seems fine, there were no loose wires. What I did notice was when the up and down keys are pressed you hear the hum of the motor trying to move and when you give the hand wheel a touch or a slight nudge it starts to move. It is the same going up or down and at all areas of the column not just one spot. If I do this a couple of times it seems to warm up so to speak but then all of a sudden it stops engaging again when the button is pressed unless you give the hand wheel a nudge again. It almost seems that it is not getting enough initial torque to get it moving because when it's moving it sound and feels smooth all the way up and down the column.
Any ideas of what I can do or check next.
cdntoolmaker
Logged
Reply #6 on:
March 08, 2010, 08:59:45 AM »
Sounds like the drive may be bad, can you swap out the drive for one from the other axis and try? If the Z has a separate power supply from the other axis check to see its not failing under load.
Logged
Overloaded
4,923
Reply #7 on:
March 08, 2010, 09:19:39 AM »
Accel rate possibly too high ?
Would be similar symptoms ?
Check tuning ?
RC
Logged
cdntoolmaker
8
Reply #8 on:
March 08, 2010, 09:32:21 AM »
I don't think its the accel rate because I have been running this Deepgroove1 Taig for almost 4 years and it just started to happen. As for swapping out the drivers I think that's a little advanced for me as I am a toolmaker not an electrician. I can check voltage and for loose connection's but that would be the extent of it.
cdntoolmaker
Last Edit: March 08, 2010, 09:37:34 AM by cdntoolmaker
Logged
Reply #9 on:
March 08, 2010, 09:37:29 AM »
Just double check to make sure that the accel is what you originally had. However if the motor was stalling you would hear it I think.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
