Hello Guest it is August 26, 2026, 09:55:51 PM
Author Topic: I'm out of OEM Triggers  (Read 13149 times)
« on: February 06, 2010, 04:26:11 PM »
I used up all 15 of the oem triggers and would like to know if it's possible to use brains and pokeys to add more trigs.
My problem is I can't figure out how to make mach see the inputs from the pokeys.
Is there a mod address assigned to every pokeys pin or only the analog pins (43-46)?
The brain I am trying to do is basically:
Pokeys pin x.....No op pass through.....Button press
Can this be done outside the 4 analog pins?
Thanks in advance,
Marc
Re: I'm out of OEM Triggers
« Reply #1 on: February 06, 2010, 05:05:45 PM »
Could you only assign hot key to the pokeys input.
Jeff
« Reply #2 on: February 06, 2010, 07:02:26 PM »
Actually, I'm trying to set jog increments with external buttons and as far a I am aware, there is no hotkey for that function.
Thanks for the reply
Marc
« Reply #3 on: February 06, 2010, 09:29:56 PM »
I set up a small macro and use a single button to cycle through 5 increments. Would that work for you?
« Reply #4 on: February 06, 2010, 10:45:40 PM »
That's probably what I'm going to end up doing as well.
I  hoped that I could do it using brains because I've already wired three rotary switches that will have to be undone/removed from my control panel......bummer
Thanks for the reply,
Marc
« Reply #5 on: February 07, 2010, 03:41:01 PM »
yes you can extend the stuff ad-nausium......
in the "PoKeys.set on the pokeys page, with the combination of the poKeys config, you can assign your inputs,
to trigger User LEDs, in a range (2 ranges of inputs possible).
Then In Brians, look at the Uled that represents that PK Pin, do a no op, then to a button press.
IF the button priess you want is NOT in Brians, that is ok, cause you can use MacroPump to with the DoButton(*********)
OEM code to press buttons from the macro pump.
scott
« Reply #6 on: February 07, 2010, 06:52:29 PM »
scott
Thanks I will give this a try
Marc
« Reply #7 on: February 08, 2010, 02:17:09 PM »
scott
Scott,
I just wanted to report back and say "Thanks". I got it working following your instructions and I would have never figured it out without your input.
Thanks again,
Marc
