Hello Guest it is October 04, 2026, 09:49:09 PM
Author Topic: Help with my rotary table speed. Beginner.  (Read 8748 times)
« on: February 02, 2010, 09:09:36 AM »
  How do I speed up my rotary table without changing the other axis speeds?  It's a pain to edit the code and add the speed on every line. Some of the lines can't be changed and my rotary turns about 2 degrees a minute.
( for Mach2/3 from Vectric )
( Y Values are wrapped around the X axis )
( Y Values are output as A )
N130 G00G20G17G90G40G49G80
N140 G70G91.1
N150 T1M06
N160 G00G43Z0.7874H1
N170 S35000M03
N180(Toolpath:- Pocket 2)
N190()
N200 G94
N210 A0.0000 X0.0000 Z0.7874 F10.0
N220 G00 X-0.0304 A25.5282 Z0.2362
N230 G1 X-0.0304 A25.5282 Z-0.0300 F10.0
N240 G1 X-0.0238 A25.6630 Z-0.0300 F10.0
N250 G1 X-0.0170 A25.7061 Z-0.0300
N260 G1 X-0.0112 A25.6685 Z-0.0300
N270 G1 X-0.0056 A25.5487 Z-0.0300
N280 G1 X-0.0003 A25.3422 Z-0.0300
N290 G1 X0.0045 A25.0512 Z-0.0300
N300 G1 X0.0086 A24.6795 Z-0.0300
N310 G1 X0.0116 A24.2372 Z-0.0300
N320 G1 X0.0134 A23.7532 Z-0.0300
N330 G1 X0.0139 A23.2457 Z-0.0300
N340 G1 X0.0132 A22.6484 Z-0.0300
N350 G1 X0.0108 A22.0759 Z-0.0300
N360 G1 X0.0069 A21.5660 Z-0.0300
N370 G1 X0.0018 A21.1471 Z-0.0300
N380 G1 X-0.0039 A20.8234 Z-0.0300
N390 G1 X-0.0101 A20.5915 Z-0.0300
N400 G1 X-0.0167 A20.4528 Z-0.0300
N410 G1 X-0.0235 A20.4077 Z-0.0300
N420 G1 X-0.0292 A20.4450 Z-0.0300
N430 G1 X-0.0347 A20.5627 Z-0.0300
N440 G1 X-0.0400 A20.7644 Z-0.0300
N450 G1 X-0.0447 A21.0490 Z-0.0300
N460 G1 X-0.0488 A21.4173 Z-0.0300
N470 G1 X-0.0519 A21.8596 Z-0.0300
N480 G1 X-0.0537 A22.3442 Z-0.0300
N490 G1 X-0.0542 A22.8516 Z-0.0300
N500 G1 X-0.0535 A23.4554 Z-0.0300
N510 G1 X-0.0511 A24.0337 Z-0.0300
N520 G1 X-0.0472 A24.5503 Z-0.0300
N530 G1 X-0.0421 A24.9772 Z-0.0300
N540 G1 X-0.0365 A25.2983 Z-0.0300
N550 G1 X-0.0304 A25.5282 Z-0.0300
N560 G00 X-0.0304 A25.5282 Z0.2362
N570 G00 X-0.0289 A26.8046 Z0.2362
N580 G1 X-0.0289 A26.8046 Z-0.0300 F10.0
N590 G1 X-0.0334 A26.6655 Z-0.0300 F10.0
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Help with my rotary table speed. Beginner.
« Reply #1 on: February 02, 2010, 12:06:29 PM »
Have you got 'Use diameter for feedrate' set in config toolpaths, and also the A axis rotation radius (should be diameter I think) set in setting screen.
Graham
