Hello Guest it is October 23, 2026, 12:05:04 PM
Author Topic: reversing coordinate system  (Read 10749 times)
« on: January 27, 2010, 02:24:18 PM »
hello all. i have been a machinist since i could stand on a milk crate and run a lathe or mill. i understand the coordinate system perfectly. i just finished a router build and having a little trouble.my y axis and x axis are opposite. i jog either axis and after doing a ref all home, the y, goes negative on the DRO. as does the x axis. my home switches are in the "0" positions. z at max height, the x on the bottom left(a and x axis are slaved, gantry style router), and the y axis bottom. do i need to switch the wires or is there a general config setting i am missing.
thanks all!
Chip
Re: reversing coordinate system
« Reply #1 on: January 27, 2010, 02:28:59 PM »
Config menu then Homing and limits and reverse.
« Reply #2 on: January 27, 2010, 02:34:25 PM »
about 18 seconds after i posted the thread i realised that was it. thanks so much! problem solved!!
thanks hood for the quick reply!!
« Reply #3 on: January 27, 2010, 02:38:50 PM »
No problem :)
