Hello Guest it is October 29, 2026, 09:11:41 AM
Author Topic: Break-In Wizard  (Read 34620 times)
Re: Break-In Wizard
« Reply #10 on: May 21, 2012, 12:18:03 PM »
The 1.0 version is now released!!
Look on the first post in the thread for general instructions, look at the bottom of this post for the new code.
Not much changed other than some text and message box messages. The code seems to be pretty solid at this point.
Please donate to the development of the Break In Wizard to bring it to a full 6-axis, non-Mach3 proprietary wizard, or if the current one has helped you in any way.
http://www.33degreeseastww.com/wizard.shtml
« Last Edit: May 21, 2012, 12:21:19 PM by swaggs21 »
Re: Break-In Wizard
« Reply #11 on: January 29, 2013, 04:50:48 PM »
I just downloaded the break-in wizard (rev 1.0) and I have a small issue with it : I can load it but when it's on the screen it only show the fields aboute min/max axis. spindle speed.. etc.
On the right of the screen I can see there are some buttons (I can see grey or green boxes) but nothing else shows : no text to tell me what the boxes are referring to..
I also don't have to buttons to export g-code or anything.
Is this a known issue or can it come from my computer configuration ?
Thanks for any help
Ben
Re: Break-In Wizard
« Reply #12 on: January 31, 2013, 09:03:24 AM »
It seems that the buttons did not make it into your Mach3 BreakIn wizard folder, can you check that they are there? They are image files.
Re: Break-In Wizard
« Reply #13 on: February 03, 2013, 05:29:54 PM »
Yep that was it, the images were not in the correct folder... It's working perfectly ! Thanks !
