Hello Guest it is November 13, 2026, 09:43:09 AM
Author Topic: Acceleration problem  (Read 25534 times)
Offline faby
  •  74 74
Re: Acceleration problem
« Reply #10 on: September 23, 2006, 12:55:01 PM »
Ok, I think you are on the right way...
In the software that I'm using for 5 years, there's something like "angular discrimination", that set where place a curve, or a deceleration, and where not.
There's a way in mach3 to modify that value?
Faby
Offline fdos
  •  326 326
« Reply #11 on: September 23, 2006, 03:16:50 PM »
This is a question for Art I think!
You can see the same if you move one axis backwards and forwards the same distance(say -100mm to +100mm to -100mm)and keep repeating .  as you increase the feedrate the distance moved becomes shorter and shorter.
Wayne....
« Last Edit: September 23, 2006, 03:19:04 PM by fdos »
Offline faby
  •  74 74
« Reply #12 on: September 24, 2006, 04:00:07 AM »
Mhh I'll try...
I tried to increase the acceleration ramp and my square become magically a circle.
I'll wait for an art answer  :) I'm sure that they could solve it
« Reply #13 on: September 24, 2006, 03:16:00 PM »
There is the angle and the CV feedrate on the settings page :) With this you can set the MAX CV feedrate that that will change the size of the Arc from move to move.
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
