Hello
Guest
it is
October 19, 2026, 01:04:54 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Stragen events question
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
Go Down
Author
Topic: Stragen events question (Read 92306 times)
NormB
169
Norm
Re: Stragen events question
Reply #50 on:
January 18, 2010, 06:45:21 PM »
Oh my, I just thoght of something. The computer has a wireless mouse and keyboard and the ocntroller was between them.........next to the sending unit..............
?? That is a radio freq. not sure how hight but it can be noise....
Logged
Carnoustie, Scotland
Reply #51 on:
January 18, 2010, 06:48:10 PM »
Could be the keyboard but I am thinking most likely the plugs maybe had a bad contact. maybe a slight bit of corrosion on them and swapping them has scraped it off, hopefully its all cured now, time will tell.
Logged
NormB
169
Norm
Reply #52 on:
January 18, 2010, 06:51:19 PM »
I hope this is not normal for these. This will drive you wacky........I guess I need to run it as is moving the controller away from the computer and see what happens. I suppose I can move it back to where I had it and run again to see if it acts up that would tell if it's the keyboard or not.
Logged
Reply #53 on:
January 18, 2010, 06:55:09 PM »
yes thats probably what I would do as well, I hate not to know what went wrong, almost as bad as it still happening
Logged
NormB
169
Norm
Reply #54 on:
January 18, 2010, 06:56:10 PM »
I also set Zero for Z with a block and at the end of the run I checked to see if it returned to Zero and yes it did. Trying to make sure it didn't loose steps. Can the router noise do something like this I did not have the router running for this test just the drives so I could hear them.
Logged
NormB
169
Norm
Reply #55 on:
January 18, 2010, 06:57:21 PM »
Exactly if you know what went wrong you can fix it........but this is a devil waiting to surface again. that is my fear........not knowing is scary..........
Logged
Reply #56 on:
January 18, 2010, 06:58:36 PM »
Ah yes, router could well produce a lot of noise, does it have brushes? If so check to see they are good condition.
Logged
NormB
169
Norm
Reply #57 on:
January 18, 2010, 07:03:41 PM »
This router only has a few hours on it......it's a roybe 2 3/4 horse.......I will check but they really should be fine. For noise you are looking for a chatter or freq. type noise right......like a bad high speed bearing and it's squeal. Radio noise something like that brushed arching will make a lot of noise I can make sure they are tight and in good condition it's a thing to look at.......
Logged
NormB
169
Norm
Reply #58 on:
January 18, 2010, 07:06:25 PM »
You know that is not correct it's a bosch router but it is 2 3/4 horse........I don't think make has mch to do with it if the brushed are okay or not is the issue.
Logged
Reply #59 on:
January 18, 2010, 07:09:24 PM »
Probably the best bet is do a few more tests in the same position but with the router running, if its ok then put it back where it was and try a few more, if all is still good then it would seem the likely cause was the connectors.
Logged
Print
Pages:
1
2
3
4
5
6
7
8
Go Up
« previous
next »
