Hello Guest it is October 07, 2026, 05:55:05 PM
Author Topic: Using the COM API in VB .NET  (Read 25672 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: Using the COM API in VB .NET
« Reply #11 on: February 09, 2010, 11:58:55 AM »
Check the MAch3 developers documentation , theres a few documents around that describe the various button codes.. the Wiki as well documents them
Art
Offline TonyG
  •  12 12
« Reply #12 on: February 09, 2010, 04:36:20 PM »
I looked at the XLS file that Brett pointed to.  If I understand it correctly, the old number for the Reset button is 1021 and the new number is 44600.  I'm not sure if I should be using old or new.  I tried 1021 and it didn't work, and 44600 is too large for the function call (DoButton function takes a short which in VB is -32k to +32k).
Where can I find the developer's document that Art mentioned?
Offline TonyG
  •  12 12
« Reply #13 on: March 04, 2010, 01:13:54 PM »
I still need some help figuring out how to activate the buttons through the ActiveX Server.
