Hello Guest it is September 26, 2026, 05:51:52 PM
Author Topic: MacroPump Doesnt Run  (Read 28672 times)
« on: January 14, 2010, 10:33:40 AM »
I have it named MacroPump.1ms
I have the use macro pump box ticked on the Config General Config page
It runs correctly if i open it with the Mach VB script editor
Anyone have any ideas what's wrong ?
Phil
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: MacroPump Doesnt Run
« Reply #1 on: January 14, 2010, 07:37:22 PM »
Make sure it is the same folder as your profile name:
If you load "myprofile" it will be in:
C:\Mach3\macros\myprofile\macropump.m1s
Also you have to restart Mach after checking the macropump box.
« Last Edit: January 14, 2010, 07:43:27 PM by zealous »
« Reply #2 on: January 15, 2010, 04:38:38 AM »
Thanks Jason
It is in the profile folder, & Mach has been restarted.
Is there any other way of checking that its working other than what it is supposed to do ?
Phil
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: January 15, 2010, 09:57:40 AM »
Put this in the Macropump to check:
Code: [Select]
i=i+1
message "Macro Running #"&i
 it will show you in Mach’s statues line how many times the macro has ran.
« Last Edit: January 15, 2010, 09:59:40 AM by zealous »
« Reply #4 on: January 15, 2010, 11:01:08 AM »
Thanks Jason,
It does run. ;D
It just doesn't like my macro, there are only 4 lines.  ::)
If(GetLED(801)=1)Then
DOOEMBUTTON (1021)
MESSAGE " Went Into Inch Mode"
end if
No laughing. :-[
Phil
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: January 15, 2010, 11:21:01 AM »
You'll need to use "GetOEMLED"... but more important use "True/False":
Code: [Select]
Dim Inch_LED_boolean As Boolean
Dim Inch_LED_interger As Integer
Inch_LED_boolean = GetOEMLED(801)
Inch_LED_interger = GetOEMLED(801)
MsgBox "boolan "&Inch_LED_boolean
MsgBox "Number "&Inch_LED_interger
'Number way
If(Inch_LED_interger = -1)Then
MsgBox "Number lookup"
End If
'Boolean way
If(Inch_LED_boolean = True)Then
MsgBox "boolean lookup"
End If
'Boolean way with out  ==
If(Inch_LED_boolean)Then
End If
If Not(Inch_LED_boolean)Then
End If
« Last Edit: January 15, 2010, 11:23:08 AM by zealous »
« Reply #6 on: January 16, 2010, 04:29:25 PM »
Jason,
Thanks i got the macropump to work, but now it resets itself and just leaves my message i want it to stay in reset mode.
Obviously VB scripting is not an area where i excel, do i need an else somehow  :-[
Phil
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #7 on: January 16, 2010, 04:47:17 PM »
Great,
You can put a sleep in there to clear the message.
Code: [Select]
Sleep(2000)'2 seconds
MESSAGE ""
End If
...you might want to use a userlabel or ticker as well as well.
In Screen4 you'll want to drop a Userlabel or ticker:
Code: [Select]
SetUserLabel 12, "You must enter a whole number of holes"
SetTicker 205, "This is a very long error message because you seem to have done something very silly"
« Last Edit: January 16, 2010, 04:52:41 PM by zealous »
« Reply #8 on: January 17, 2010, 10:57:26 AM »
Hi Jason,
Thanks for your patience in helping this dummy. :-[
I want the message to stay i just want the event once its happened to leave the machine disabled until i reset the machine.
Is that possible.?
Phil
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #9 on: January 17, 2010, 12:50:06 PM »
Hi Phil,
Let me get a better idea of sequence of events.
If the machine goes into Inch mode, no matter what it is doing Estop(reset) the system, send a message about being in Inch mode and wait for a "reset" before removing the message?
Are you using the VB popup message display or the Mach label message display?
Jason
