Hello Guest it is November 10, 2026, 01:57:29 AM
Author Topic: MacroPump Doesnt Run  (Read 29202 times)
Re: MacroPump Doesnt Run
« Reply #10 on: January 17, 2010, 03:46:35 PM »
Hi Jason,
All correct in your observation and i am using the Mach label message display.
Phil
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #11 on: January 17, 2010, 04:34:59 PM »
I give the user 2 seconds to change it to MM after the estop is hit or it estops the sytem again.
Code: [Select]
Dim Inch_mode As Boolean
Dim Estopped As Boolean
Estopped = GetOEMLED(800)
Inch_mode = GetOEMLED(801)
If(Inch_mode)Then
'Is the sytem estopped already
If Not(Estopped)Then
'Estop system
DoOEMButton(1021)
End If
While(GetOEMLED(800))
MESSAGE "Went Into Inch Mode:"&i
sleep(250)
Wend
'Give the user time to change to mm?
Sleep(2000)
End If
« Reply #12 on: January 17, 2010, 04:55:37 PM »
Hi Jason,
Thank you so much, it beats checking a custom screen with a flashing red led 25mm x 50mm while turning the MPG. ;D
It's so easy when you know how, i would never have got that.
Phil
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #13 on: January 17, 2010, 08:47:43 PM »
Great to hear!
I wasn't sure that was what you wanted, but you can make changes and maybe have it force it back to MM mode or something :)
« Reply #14 on: January 18, 2010, 09:45:59 AM »
Jason,
I can understand the workings, with a bit of thought  :-[, but why fix something that isn't broke. ;D ;D ;D
Phil
