Hello Guest it is November 22, 2026, 06:04:40 PM
Author Topic: referencing not working in mach 3  (Read 12480 times)
« on: September 19, 2006, 07:06:40 PM »
i have a problem with mach 3 referencing to home. using input pin 11 for x, pin 12 y,pin 13 z. when referencing ,mach 3 hits the limit and the estop trips, does not back off the switch. i hve to switch off motor power and hand crank off the switch. limit overide does not work. the estop wont reset.
tried this setup with mach 2 and works no problem.
Re: referencing not working in mach 3
« Reply #1 on: September 20, 2006, 06:20:45 AM »
Do you have the limit set up and not the Home input ?
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: September 20, 2006, 11:08:23 AM »
solved it. i set the debounce to 500 and now works . thanks Brian.
