Hello Guest it is November 13, 2026, 05:47:21 AM
Author Topic: No pulse line box  (Read 26883 times)
Re: No pulse line box
« Reply #10 on: December 29, 2009, 09:13:10 AM »
There are 74.5GB of memory.  Thanks, Jimmy
« Reply #11 on: December 29, 2009, 09:17:58 AM »
Thats you hard drive size, it is RAM that is important, min if using XP should really be 256 Meg but 512 or more would be better.
« Reply #12 on: December 29, 2009, 09:53:20 AM »
261,424 MB RAM, windows 2000.  I think that is right.  Thanks, Jimmy
« Reply #13 on: December 29, 2009, 10:01:25 AM »
Think thats probably Kb, if so then that should be plenty for Mach on windows 2000.
Have you tried the computer with some motors to see how they perform?
« Reply #14 on: December 29, 2009, 10:21:39 AM »
The motors do not run.  I am just starting to get the Mach running.  I did the special driver and now have no pulse.  Thanks, Jimmy
« Reply #15 on: December 29, 2009, 10:24:50 AM »
I thought maybe the special driver would work when you said you had no line so best just go back to the original.
Might be worth doing the optimisation steps detailed on the downloads page (near the bottom)
« Reply #16 on: January 08, 2010, 09:09:51 AM »
I changed computers and now have a good pulse rate and line with very little spikes, but the motors still do not run.  I have used the Gecko troubleshooting diagram and have come down to the "check controller timing G203V step input specs: min step '0' time = 0.5 uS min step '1' time =3 uS".  Could someone explan this and how do you correct ifd it is not right.  Thanks, Jimmy
