Hello Guest it is November 10, 2026, 01:57:47 AM
Author Topic: Detecting Button Presses  (Read 22624 times)
Re: Detecting Button Presses
« Reply #10 on: May 10, 2010, 08:32:21 PM »
I started looking into this issue but found your zip file is no longer available. Thought id attempt to try to solve this through a plugin. Wanted to get an update on your progress. And any info that might be handy. Thanks for what you did post.
« Reply #11 on: May 10, 2010, 08:56:05 PM »
Hey,
Thanks for the interest. The project took a few different turns and is now a visual c++ plugin. However I did get it working and it will detect any button presses globally.
Theirs now alot to the plugin, most of it is the keyhook initialization in the main config form.  I have not touched the file in many months, work sent me around town and back to school and I wont be able to take a crack at it again for a month or two more.
My goal was to add a feature to the keyhook library to consume keypresses and make a better config interface. Good luck!
http://www.4shared.com/file/bmJAjlgU/CustomPluginDLL.html?
