Hello Guest it is November 13, 2026, 05:18:13 PM
Author Topic: Jog Controls Dropping Out  (Read 6778 times)
« on: December 19, 2009, 10:50:24 PM »
I have installed the new Joystick Plugin for my Lathe ( x-z ). The X axis dropped out  after 1 try and I had to restart Mach 3 before it worked again. Also, if I change to MPG jogging, use the MPG and then change back to Continuous Jogging, the joystick won't work again until I restart Mach 3.
Sometimes I have to restart Mach 3 to get the MPG to work in the first place.
Is this a Mach 3 problem or a Windows XP problem ?
Is anyone else having this problem ?
Glen.
I had a few parts left over - still it's always the same when you try a bit of "do it yourself"
