Hello Guest it is November 13, 2026, 08:56:47 PM
Author Topic: Is this a valid line of VB script?  (Read 12326 times)
« on: December 18, 2009, 06:20:30 PM »
I'm troubleshooting an OEM macro (that seems to work in version .029 but not in version .032) with little VB knowledge. It contains a line that I can't figure out:
"wait = GetOEMLED(11) = 0"
Is this line with two "=" symbols valid and if so can someone tell me what it is trying to do?
Thanks - Terry
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Is this a valid line of VB script?
« Reply #1 on: December 18, 2009, 11:40:36 PM »
In VB "=" means this equals that
Code: [Select]
wait = 4
msgbox wait 'returns 4
or
Code: [Select]
this = true
that = true
if this = that then
msgbox "they are the same"
End If
You would have to provide more of the code to figure out what is meant to happen.
Spindle ON LED (CW or CCW) = GetOemLED(11)
Are you checking to see if the spindle is on and how long to wait for?
Code: [Select]
Wait = 1000
If GetOEMLED(11) = True Then
Sleep(wait)
End IF
« Reply #2 on: December 19, 2009, 03:26:41 AM »
I'm still confused though about what the two equal signs on the same line are trying to do. It seems that a variable 'wait' is being assigned the boolean result of Get OEMLed(11), but what is the "=0" at the end doing? - Terry
« Reply #3 on: December 19, 2009, 03:37:29 AM »
looks to me that its saying to wait if OEMLED 11  is equal to zero, ie off.
« Reply #4 on: December 19, 2009, 02:22:00 PM »
Thanks - Terry
It would be better written:  "wait = (GetOEMLED(11) = 0)".  It is valid, but perhaps poor coding practice.  GetOEMLED(11) = 0 will be evaluated as a boolean expression, returning TRUE if OEM LED 11 is Off (0).  So, wait will be set to TRUE (non-zero) if LED 11 is Off, and FALSE (zero) if LED 11 is on.
