Hello Guest it is November 13, 2026, 09:43:51 AM
Author Topic: It's Alive!! It's Alive!!! (Insert Maniacal Laughter Here...)  (Read 30233 times)
Offline thosj
  •  542 542
Re: It's Alive!! It's Alive!!! (Insert Maniacal Laughter Here...)
« Reply #10 on: December 11, 2009, 12:06:10 PM »
\I've got the commercial one sitting on my work table.  I had my own almost complete by the time it showed up, so never got it on the machine.
So......what ARE you going to do with the commercial one?
Tom
« Reply #11 on: December 11, 2009, 12:51:26 PM »
Good question....  Probably sell it.  I like mine better.
« Reply #12 on: December 13, 2009, 12:24:52 AM »
I got the oddball bolts I needed to put the top of the mill back together, so I have a working mill again!  I'll be doing the first test cuts with the new quill drive tomorrow.  I did some probing tests today, and it seemed to work flawlessly, getting +/-0.0001" repeatability!
« Reply #13 on: December 16, 2009, 10:19:32 AM »
Nice job, Ray. Much better than powering the rack and pinion drive which I have seen many tmes.
I'm noticing the seals on the ballscrew. What ball screw did you use?
« Reply #14 on: December 16, 2009, 11:01:01 AM »
The screw is a 30mm, 5mm pitch from homeshopcnc.com.  It's *very* nice.  Smooth, quiet, zero backlash.  I'm seeing well under 0.001" total backlash at the tool, and virtually all of that comes from flexing of the quill itself.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #15 on: December 16, 2009, 11:05:14 AM »
Nice looking conversion, I guess the hardest part will be making a nice looking cover. Clear Poly Carb so you can see it working maybe.
Graham
« Reply #16 on: December 16, 2009, 11:21:08 AM »
Graham
Graham,
    Yup, it'll be either plastic (Plexi/Lexan) or just sheet metal.  Each has it's good points and bad points.  I'm kinda leaning towards 1/8" Plexi, since I'm already setup to do Plexi vacuum forming.
