Hello Guest it is November 11, 2026, 08:06:36 PM
Author Topic: Whose Fault Is ThIs?  (Read 84160 times)
Re: Whose Fault Is ThIs?
« Reply #50 on: February 29, 2012, 06:08:25 AM »
Brian,
Will you elaborate on the changes made to CV in .058?  I don't recall seeing this discussed anywhere, but may have missed it.  I ask because I'm using .058 and M10/M11 commands with my small laser diode machine and noticing some problems with incomplete lines and circles in some cases, but haven't yet been able to fully diagnose a cause
John Champlain
www.picengrave.com
« Last Edit: February 29, 2012, 06:10:44 AM by Picengraver »
« Reply #51 on: February 29, 2012, 05:47:50 PM »
Test it out on a sample code and it worked! Here's to crossing my fingers that the problems gone forever!
Odd. I have been using helical cutting and thread milling with CV for ages with the lock-down version. No problems at all.
That would depend on your definition of ages! Also, you might not have noticed! The errors accumulated slowly. I only noticed when I was doing a very precise cut on a reflector mold!
Last time I tried it was 5 or 6 months ago and it still didn't work. If you look at when I posted, and the rest of the thread you'll see that the bugs always been around!
