Hello Guest it is November 08, 2026, 12:34:33 PM
Author Topic: how do i get the spindle to run on a taig and gecko 540 controller???  (Read 13673 times)
hi every one i have a taig cnc mill and a gecko 540 controller and i have a problem trying to run the  spindle ...i cant get it to turn on  the plug going to the motor is connected to the gecko control er  but i don't know how the to get it to run ...i went to mach 3 videos and watch them but i still cant get it to run is there...   every thing esle work great i  just don't know what i am doing wrong  please help if some one had the same problem
Re: how do i get the spindle to run on a taig and gecko 540 controller???
« Reply #1 on: November 18, 2009, 08:47:12 PM »
I'm having a bit of trouble understanding your setup. But to turn the spindle on and off via Mach3 through the G540, you need to have the G540 control a relay that turns the power to the spindle on/off
Once you have set it up you should be able to use the M3/M4 and M5 words to control the spindle from GCode.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: November 18, 2009, 09:02:40 PM »
would the  the gecko already have the relay in it ????
« Reply #3 on: November 18, 2009, 10:30:16 PM »
Absolutely not. Have a look at the sample setup diagram GeckoDrive manual. It shows you how to control the relay.
http://www.geckodrive.com/upload/G540%20REV4%20MANUAL.pdf
Cheers,
Peter.
Homann Designs
« Reply #4 on: November 18, 2009, 11:24:46 PM »
so were do i buy  the relay at and how do i install it
