Hello Guest it is November 13, 2026, 12:46:29 PM
Author Topic: List of suitable PCI parallel ports  (Read 28761 times)
Re: List of suitable PCI parallel ports
« Reply #10 on: November 18, 2009, 02:36:03 PM »
with the moschip pci try the 9735 driver. i think that was the one that worked for me.
Guessing you meant 9835.  Moschip didn't have a 9735 available.  The 9835 driver had the same results as the 9805.  I'm thinking it's time to try a Pokeys..or maybe just go to a SmoothStepper.  I read on the SmoothStepper site that compatibility with Mach3 may not be quite there yet.
« Reply #11 on: November 19, 2009, 02:05:26 PM »
If you do a search here on the forum you will find a post I made with the exact card, drivers, source and instructions on how to add a MACH compatible PCI port card.
