Hello Guest it is November 24, 2026, 11:09:12 PM
Author Topic: parallel port problems  (Read 35339 times)
Re: parallel port problems
« Reply #10 on: November 17, 2009, 02:35:24 AM »
That is why I said to change the active state of the E-Stop in Ports and Pins. It will fool Mach into thinking you have a Normally Open E-Stop switch fitted. The other option would be to put a jumper wire between pin 10 and Gnd on your Uniport board.
« Reply #11 on: November 17, 2009, 03:45:57 AM »
That is true. I will try to ground the pin 10.
However, I am surprise about MACH3 behaviuor. Why I am not able to deactivate and save the E-stop output flag. This appear strange to me.
Marco
« Reply #12 on: November 17, 2009, 04:23:36 AM »
Because it is unsafe to run a CNC machine without a proper E-Stop.
« Reply #13 on: November 17, 2009, 07:57:40 AM »
Does it mean that for a real test I have no chance; or I connect the E-stop button to the UNIPORT, or I ground the correspondent input?
« Reply #14 on: November 17, 2009, 08:08:58 AM »
What it means is you can trick Mach into thinking you have a switch there by either
Changing the active state of the E-Stop input in Ports and pins
or
Shorting pin 10 to gnd on your Unipor and leaving the Input as Active High.
or
lastly connect a NC E-Stop switch
« Reply #15 on: November 17, 2009, 04:43:01 PM »
Finally I see the light from the tunnel.  :)
No chance to change the active status of E-stop by software. Do not ask me why.   ???
The problema has been solved by put to ground the input of E-stop. Following that, the UNIPORT works fine, and I can execute Gcode in ‘online’ mode and the drivers and motors do their job.
Now I am ready to start to take practice with MACH3.
Thank you Hood for your support
Marco
« Reply #16 on: November 17, 2009, 04:48:48 PM »
No probs :)
« Reply #17 on: May 19, 2010, 12:00:35 AM »
So I tried the suggestions as stated in the thread, but am still having the same problem nothing is lighting up for me.  Thanks for your help.
« Reply #18 on: May 19, 2010, 09:29:53 AM »
What is your problem?
« Reply #19 on: May 19, 2010, 09:35:32 AM »
My problem is when I jog the machine in the software, none of the lights show up in the diagnostics screen. I think it has to do with the Estop, but I can't figure it out.  I tried making active hi, and active low, but it doesn't seem to work.
(I probably should have started with a new thread, but my problem is the exact same as shown here.)
