Hello Guest it is November 24, 2026, 09:23:02 AM
Author Topic: Problem with XBOX 360 Pendant...?  (Read 34938 times)
Re: Problem with XBOX 360 Pendant...?
« Reply #20 on: May 05, 2012, 10:11:25 AM »
What operating system are you using?
What kind of computer are you using?
I'm using Win XP and have an older motherboard with an on board parallel port, even though the XBOX controller is USB, I don't have any trouble. I'll go out this morning and check my exact settings and get back to you.
« Reply #21 on: May 05, 2012, 12:05:53 PM »
First, make sure the four light button has only one light on and it is in the top left corner. The only other settings I have is  in "port and pins" I have output settings, output #3 enabled, port #1 pin #17. If you still can't get to work, PM me your email and I'll send a picture of my XBOX set up screen.
