Hello Guest it is October 20, 2026, 02:51:57 PM
Author Topic: Probing plugin not wizard?  (Read 14101 times)
Offline Fastest1
  •  920 920
  • Houston, TX
« on: November 11, 2009, 04:07:28 PM »
Where is it? I updated Mach to the latest rev .032 and expected to see the plugin on the top of the mach screen but it isnt there. The probing wizard by Art is there. Is the plug in still available? It had features like center finding. I am not sure if it all worked as I do remember a dialog box that would never close "prev seq not complete etc. Anyone famiiar with it?
Offline mry
  •  8 8
Re: Probing plugin not wizard?
« Reply #1 on: August 09, 2012, 01:10:15 PM »
currently searching for the same.. per a post over on cnc zone..
looking for the "config>configplugins > 3d probing plugin?
help???
« Reply #2 on: August 09, 2012, 02:20:39 PM »
Is this the one you are looking for?
Offline mry
  •  8 8
« Reply #3 on: August 17, 2012, 07:28:57 PM »
maybe? unfortunately I was unable to unzip? the rar file?
Offline mry
  •  8 8
« Reply #4 on: August 17, 2012, 08:33:03 PM »
got it installed. got my 3d probing menu..
managed to run the routine. but kept getting previous seq not complete between each step.
did NOT see any gcode developed when running the plugin?
what in the world am I doing wrong.
Offline mry
  •  8 8
« Reply #5 on: August 19, 2012, 04:32:19 PM »
seems like the plugin doesnt work at all for me..
back to the digitize wizard.
« Reply #6 on: February 08, 2013, 06:39:29 PM »
I used this plug in in Mach version .022 and it was great. I would find center of circle create 3d point clouds.
It did not generate gcode on the screen at any time just went to center after touching 4 side of a circle and told you you were centered.
It generated a point cloud that could be imported into Autocad or whatever that could then be made into gcode.
Since I upgraded to the latest version of Mach .066 I get the same thing!"previous sequence not completed".
Don't know what happened but maybe someone at Artsoft can chime in and help us out.
I have this ultimate set of tools I can fix it.
