Hello Guest it is September 10, 2026, 12:19:00 AM
Author Topic: Can i use mach3 for dispensing?  (Read 12949 times)
« on: November 09, 2009, 07:46:35 AM »
i found this option in winpc-nc software
Can mach3 do the same?  I can use dwell, but specially I need to activate some  output  signal before the line end!!!
« Last Edit: November 09, 2009, 07:51:07 AM by znak »
Re: Can i use mach3 for dispensing?
« Reply #1 on: November 09, 2009, 08:56:59 PM »
Look at this thread, maybe it what you are looking for, I hope
Jeff
http://www.machsupport.com/forum/index.php/topic,11158.msg70185.html#msg70185
« Reply #2 on: November 10, 2009, 05:44:46 AM »
very good thread about donming machine, but i`m using gear pumps with stepper-not valves, so i need to inverse my gearpump before the nozzle get to the end of the line, that why i need mach3 to give some signal before the end of the line.
maybe i can modify cam postprocessor to have some gcode but adding m-code have bad effect to lookahed function
for example: i need to travel from x0 to x100 without stopping.
gcode looks like:
g1 x0
g1x50
g1x100
if i add m7 code, for example
g1x0
g1x50
m7
g1x100
movement will be interrupted in x50 point.
tried this too, bus same result-stopping in x50point.
g1x0
g1x50 m7
g1x100
« Reply #3 on: November 14, 2009, 10:55:09 AM »
here is my video, but i still need to tune Mach3 to get signal some seconds before the nozzle goes up
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/woRTG1ZCjhg&hl=ru_RU&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/woRTG1ZCjhg&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/bBCi8TcCTZQ&hl=ru_RU&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/bBCi8TcCTZQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
