Hello Guest it is November 27, 2026, 08:14:28 AM
Author Topic: C10 BOB parallel port problem  (Read 10869 times)
« on: November 07, 2009, 07:52:02 PM »
I have just purchased a 3 axis kit from Keling that included a C10 BOB and 5vdc power supply for the board.
When I connect the parallel port cable from my pc to the C10 the led on the board and power supply lights up.(Power to the control panel is off)
Has anyone else had this problem?
I should not that I am using Mach 3 and when the control panel is turned on the machine runs properly.
David
Offline gdb
  •  6 6
Re: C10 BOB parallel port problem
« Reply #1 on: November 08, 2009, 05:42:06 PM »
Hi David, I have a C10 BOB and it works the same way. The board gets some power from parallel port when connected.
Great little BOB.
      Glen
