Hello Guest it is November 12, 2026, 01:41:49 AM
Author Topic: OEM Codes...  (Read 38513 times)
Re: OEM Codes...
« Reply #10 on: November 08, 2009, 10:02:35 AM »
Arbo is correct, it's not working. Using his example, and setting the function to Open G-code (OEM 115). When I open the screen in Screen4, the image button is set to system function "Run", but the regular button is set to OEM 115. They should be the same. Re-Opening in Machscreen, the image button says the function is "User Defined 115".
Re: OEM Codes...
« Reply #11 on: November 08, 2009, 01:21:55 PM »
Hey,
I fixed that problem in version V1.30 which is downloadable from my site.
Klaus.
The brain isn't a soap, it doesn't shrink when used.
Offline Arbo
  •  50 50
Re: OEM Codes...
« Reply #12 on: November 08, 2009, 03:00:14 PM »
Thanks for the fix.   I like how if you click on something that has more than one item where you clicked (ie image and image button) it pops up to let you select which one you want to select.  Very nice.
