Hello
Guest
it is
November 23, 2026, 01:03:36 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Re-useable lists of Parameters for use in G-Code files
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Re-useable lists of Parameters for use in G-Code files (Read 24702 times)
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Re-useable lists of Parameters for use in G-Code files
Reply #10 on:
November 14, 2009, 04:51:27 PM »
Have a look here, mach3 is based on the Fanuc 6 system type a16, i.e. it has no conditional commands or loops and no I/O commands
http://www.machinetoolhelp.com/Applications/macro/macro_variables.html
Graham
Last Edit: November 14, 2009, 04:54:49 PM by Graham Waterworth
Logged
hunserv
77
Reply #11 on:
November 15, 2009, 03:16:37 PM »
Ok, clearer now, thanks!
Occassionally I have seen on one of the links there that there is G47 for text/serial No. engraving... Mach does not support this for the moment, right? (btw. there is text engraving wizard, which does not give any output)
Logged
Print
Pages:
1
2
Go Up
« previous
next »
