Hello Guest it is October 10, 2026, 08:25:15 PM
Author Topic: Spindle% in MachTurn  (Read 9750 times)
« on: October 28, 2009, 01:50:50 AM »
I am using a Pokeys with Hood DRO code to do the spindle override. The brain viewer shows it is outputting 0-150% to Spindle% termination output as I turn the knob but the spindle stays the same speed. Hood is using it with MachMill. Should this work with MachTurn? Is Spindle% screenset dependent?
Re: Spindle% in MachTurn
« Reply #1 on: November 28, 2009, 07:47:39 PM »
Same result here. Do you have solved the problem? Anyone know why we get this result? Thank you
« Reply #2 on: December 12, 2009, 11:50:40 AM »
Jep i have the same by the mill tomoroww i post the brain
« Reply #3 on: June 25, 2010, 01:47:59 PM »
Is someone already managed to solve this problem? ???
I  have tried all sorts but do not move  DRO74 (spindle%) :(
Offline jve
  •  128 128
« Reply #4 on: August 09, 2010, 12:45:04 PM »
i have same problem i cannot move dro74 in mach3 turn but it works in the mill
