Hello Guest it is November 13, 2026, 05:55:04 PM
Author Topic: Pluging and Macro interaction?  (Read 25159 times)
Re: Pluging and Macro interaction?
« Reply #10 on: December 23, 2009, 09:54:15 PM »
I think, VBA in a Plugin is not possible.
But the access to all of the Mach3-Functions you have in VBA you have in the plugin too. The only thing it is in C, not VBA.
eg
in VBA:
Code: [Select]
Call SetOEMDRO (818, GetOEMDRO (818) * 1.1)in C in aPlugin:
scripter.SetOEMDRO(818, scripter.GetOEMDRO (818) * 1.1);
VB should be possible, but not VBA I think.
In both cases you have to compile those scripts or you have to build your own interpreter.
That's all, not more, not less.
Bye, Steffen
« Reply #11 on: December 24, 2009, 03:29:43 PM »
thanks steffen
script engine is in heart of mach and not accessible from plugins...   8) but VBA core function are available to C, i could use python or java script, but it doesn't worth it.
