Hello Guest it is November 28, 2026, 02:44:02 AM
Author Topic: Can Mach 3 be used on multiple machines??  (Read 10836 times)
Offline Garyv
  •  103 103
« on: September 05, 2006, 08:29:07 PM »
I am thinking about setting up a second Mini Mill and wondered if there is a place to save and change the configuration of Mach 3 to save all parameters on each machine so if I am running one mill  then connect to the second mill is there a fuction to save all info on each machine ?
       I just dont want to get a second computer and dont plan on running them both at the same time ..
   THanks
Re: Can Mach 3 be used on multiple machines??
« Reply #1 on: September 05, 2006, 08:46:55 PM »
That is no problem :) look in the manual about setting up a new profile. you could have a lathe and 3 mill on the same computer :)
www.newfangledsolutions.com
www.machsupport.com
Offline Garyv
  •  103 103
« Reply #2 on: September 06, 2006, 06:03:42 AM »
Thanks Brian ,
   I will check it out
