Hello Guest it is October 20, 2026, 07:55:12 PM
Author Topic: AD sure servo And smooth stepper  (Read 26357 times)
Re: AD sure servo And smooth stepper
« Reply #10 on: October 21, 2009, 04:23:39 PM »
How should the AD drive be wired for a SS board Because I  think i have it wired for single ended Step/Dir signals
Afraid I have no idea, you will have to refer to the Sure Servo manual. With the drives I use they can be set up single ended or differential, it is possible the Sure Servo ones require a parameter set .
« Reply #11 on: October 21, 2009, 05:00:17 PM »
There is an Error in the Sure Servo manual, the written doc on the Optos is wrong, the PIC of the opto wiring is correct.
scott
« Reply #12 on: October 22, 2009, 07:42:04 AM »
Here is a picture of the current wiring I have chosen to use from the AD servo manual pls check this and see if it is the correct one to use
thanks for the help
Adam
« Reply #13 on: October 22, 2009, 01:51:13 PM »
Seems to be fine although I would possibly have thought the common should have been tied to the - inputs.
