Hello Guest it is October 21, 2026, 02:04:28 AM
Author Topic: calculation for using Pulley  (Read 17272 times)
Offline Robhi
  •  138 138
« on: October 15, 2009, 05:56:55 PM »
Hello,
I would like to use pulley in order to double the speed of my machine.
The small one is a 14 teethed pulley which attached to the transmission screw of 5mm pitch.
The bigger or wider pulley is fixed on the motor (pas à pas) 200 step per revolution.
And also I have Gecko drive that is rated to 10 micro step.
How could I calculate the steps units for motor tuning please?
Robhi
Offline Robhi
  •  138 138
Re: calculation for using Pulley
« Reply #1 on: October 15, 2009, 06:02:51 PM »
Sorry...
the wider pulley has 44 teeth and the pitch is 5 for both of them..
Robhi
« Reply #2 on: October 15, 2009, 06:11:58 PM »
motor 200 steps  x 10 micro steps = 2000 steps per motor rev
Ballscrew = 5mm per rev
Ballscrew does 44/14 = 3.142 revs per motor rev so that is 3.142 x 5 = 15.714mm per motor rev
2000 steps per motor rev/ 15.714 = 127.2727272727272...................... steps per mm.
Offline Robhi
  •  138 138
« Reply #3 on: October 15, 2009, 07:08:40 PM »
hello,
now I have 400 step..
200 step motor * 10 microstep gecko 2000
2000/5 screw pitch = 400 .
so if I use 127.2727272727272 in stead of 400 , the machine goes faster?
I would like to fix the larger or wider pulley  on the stepper motor..
thanks
Robhi
« Reply #4 on: October 15, 2009, 07:25:03 PM »
Yes it will move faster because 1 turn of the motor will move the ballscrew 44/14 = 3.142857142857142857.....turns.
 With your 1:1 gearing one turn of the motor moves 5mm so steps per mm is 2000/5 = 400. But with the gearing of 3.142857........ the axis will move 3.142857.......mm for 400 steps so 400/3.142857....... is 127.272727......steps per mm.
Offline Robhi
  •  138 138
« Reply #5 on: October 16, 2009, 05:38:45 AM »
Hello,
That is great ..
Thanks Hood.
We learn somethong every day..
Robhi
Offline Robhi
  •  138 138
« Reply #6 on: October 29, 2009, 05:22:10 PM »
hello again,
how do I calculate for the rotary axis?
motor is 200 steps, Gecko 201 , small pulley (12 teeth ) is  directly attached to the chuck.  wide one is on the stepper motor 60 teeth..
60/12 = 5
5*200= 500
500*10= 5000
5000/360=13.88888.....etc
Am I right?
Robhi
« Reply #7 on: October 29, 2009, 05:29:11 PM »
One rev of motor does 5 revs of chuck as you have said
one rev of motor is 200 steps x 10 microsteps of drive = 2000 steps per rev
steps per rev of chuck is 2000 x 5 = 10,000
10,000 steps per 360 degrees  so 1 degree is 10,000/360 = 27.777777777777777777777777777777 steps
Offline Robhi
  •  138 138
« Reply #8 on: October 29, 2009, 05:36:10 PM »
 :) Merci Hood.. Thanks
Robhi
