Hello Guest it is November 13, 2026, 08:05:58 PM
Author Topic: Rotary axis display in toolpath window. Can it show B?  (Read 9918 times)
Offline Greolt
  •  956 956
« on: October 15, 2009, 05:00:16 PM »
For as long as I have been doing 4th or rotary axis work on my router I have believed that Mach can
only represent A axis correctly in the toolpath window.  Not B.
It occurred to me that before I start advising others that this is the case, I had better check that I am not mistaken and just doing something stupid.
So my question to the experienced 4th axis users.  Can the toolpath window represent B axis toolpaths correctly or not?
Greg
Offline Greolt
  •  956 956
Re: Rotary axis display in toolpath window. Can it show B?
« Reply #1 on: October 16, 2009, 10:48:31 PM »
For anybody who may have been interested Brian has confirmed what I thought,
that only A axis can be displayed correctly in toolpath window. Not B or C.
Greg
Offline Duael
  •  14 14
  • Artist
    • Robert Stein III
« Reply #2 on: September 26, 2018, 12:11:46 PM »
Hello,
This is an old post and I am a new user.
Is this still an issue with the Tool Path Display.
I have been having problems interpreting the Tool Path Display.
So I loaded this stupid simple hand written g-code to test movement directions and orientation.
The g-code results for XYZ movement result in a path that is what I expected, and is what I see the machine perform.
The g-code results of A and C rotations result in a path that is unexpected, yet the machine performs as expected.
If the Mach3 Tool Path Display is not adequate to display 5 axis movement, what viewer do you use?
~g-code~
(RS3 Basic code test of the PilotPro Orientation)
(No Spindle Test for Direction and Orientation of XYZAC)
G20
G40
G49
G80
G90
(Test of XY, 2 stair steps, 1 diagonal, return to x-1, y-1)
G54
G0 Z2.0 A0. C0.
G17
G0 X-1.0 Y0.0
G0 Y-1.0
G0 X-2.0
G0 Y-2.0
G0 X-3.0 Y-3.0
G0 X-1.0
G0 Y-1.0
G17
M6
(Test of XYZ, XY box with Z stepping upward)
G0 X-3.0 Y-1.0 Z3.0
G0 X-3.0 Y-3.0 Z4.0
G0 X-1.0 Y-3.0 Z5.0
G0 X-1.0 Y-1.0 Z6.0
M6
(Test of A HEAD, CW)
G0 A5.0
G0 A0.0
G0 A15.0
G0 A0.0
(Test of XYZA)
G0 A15.0
G0 X-3.0 Y-1.0 Z5.0 A45.0
G0 X-3.0 Y-3.0 Z4.0 A90.0
G0 X-1.0 Y-3.0 Z5.0 A45.0
G0 X-1.0 Y-1.0 Z6.0 A15.0
G0 A0.0
M6
(Test of C TABLE, CCW)
G0 C15.0
G0 C-15.0
G0 C90.0
G0 C-90.0
G0 C0.0
M6
(Test of XYZAC, XY moves to center of table, A points to C @90, C rotates 360)
G0 X-4.0 Y-4.0
G0 Z3.0 A90.0
G0 C360.0
G0 X-1.0 Y-1.0 Z6.0 A0.0
