Hello Guest it is November 13, 2026, 11:39:25 AM
Author Topic: Scaling Problem - Help Needed  (Read 29601 times)
Re: Scaling Problem - Help Needed
« Reply #10 on: October 14, 2009, 09:50:51 AM »
Yes it was set at 800 initailly but now that i have run the Automatic calculation setup this value has now reduce to 81 which is closer to your calcuation
Rick
« Reply #11 on: December 07, 2009, 03:14:38 PM »
I have the same problem. We just bought a Mach 3 KX3 milling machine. If I program 3.00 in the y, the table moves only .500, same for all three axis. Can you please explain how to fix this. Thanks you
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #12 on: December 07, 2009, 03:33:37 PM »
Where did you get the Mach3 install from, if you have MachLoader icon on your desktop run that, there should be a KX3 profile.
Graham
« Reply #13 on: December 08, 2009, 06:53:17 AM »
We bought it from a dealer in Maine. We installed it ourself.  It wasn't hard to get it installed. It just seems like the software is not working right.
  •  2,785 2,785
« Reply #14 on: December 08, 2009, 11:11:30 AM »
You need yo ask the dealer for the Mach3 XML profile for your machine if it is not listed in the machloader program.
Graham
« Reply #15 on: December 08, 2009, 11:56:06 AM »
We have the XML KX3 profile and have loaded it, but machine still moves not as programed
  •  2,785 2,785
« Reply #16 on: December 08, 2009, 02:21:54 PM »
OK, to correct this we need to know the pitch of the lead/ball screw the ratio of the motor to the screw (direct drive 1:1), the number of steps pre rev of the motor (normally 200) the setting of the stepper driver, 1(full), 2(half), 4(quarter) ,8(eighth), etc and if you intend to work in inches or mm
Graham
« Reply #17 on: December 08, 2009, 03:12:03 PM »
Ok, I will get that information, Thanks for the help
