Hello Guest it is October 23, 2026, 07:34:44 AM
Author Topic: Tool Changing problems on the lathe  (Read 37885 times)
Re: Tool Changing problems on the lathe
« Reply #20 on: October 13, 2009, 10:46:16 AM »
Art
I have already tried the standard screenset exactly the same even shut Mach down and then restarted
I just changed the code to tool 1 with all Zero offsets in the tooltable still same problem
Also get the problem with a desktop, i tried to eliminate every thing i could think of myself before asking here
I posted my xml at the beginning i don't know if Hood has tried that, there is never a move in Z only X
Phil
« Reply #21 on: October 13, 2009, 12:31:56 PM »
Dont see anything wrong with your xml and it seems to run fine here with your code.
Do you have any custom macros at all? or Brains?
« Reply #22 on: October 14, 2009, 05:09:17 AM »
Hood And Art
A big thank you for your patience with this problem.
I have solved the problem but i don't know exactly what the problem is or how it came about. :-[ :-[ :-[
Hood your last post convinced me that it was all my fault, naturally.
So i used the standard macro folder and renamed it to my profile after renaming the original folder BAD
I ran the code it worked as it should, i then copied over my tool folder from the bad folder into the standard renamed tool folder, ran again still OK
The problem is I have lots more macros in the bad folder and some that are missing.
Phil
« Reply #23 on: October 14, 2009, 05:22:29 AM »
Just have to copy the macros over one by one and see if the problem returns. Have a look at the m6End.m1s and see if there is anything in that, it should say something like Not used in Turn but maybe yours had something else in it, I am not sure if Turn would just ignore it regardless of what was in it or not.
« Reply #24 on: October 14, 2009, 05:31:41 AM »
Hood are you a sadist.
I have been wrestling with this problem for the last 4 weeks and i defiantly do not want it to return. ;D ;D ;D
Maybe when i have had it working for a while i might see what it was.
Phil
