Hello Guest it is November 08, 2026, 03:10:20 AM
Author Topic: G4 versus Sleep  (Read 37924 times)
Re: G4 versus Sleep
« Reply #10 on: October 06, 2009, 09:49:05 AM »
but I think I have come to one conclusion. Whenever you make a change to Mach, such as changing a DRO, the coordinate system, etc AND you have subsequent code that relies on those changes to be made, you should always add a While Is Moving loop after those changes to make sure Mach has completed them.  Is this correct?
Kent
Yes, for the time being but as I said above it will soon not be needed. It will however be backward compatible  so it wont require macros to be changed if you don't want to.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: G4 versus Sleep
« Reply #11 on: October 06, 2009, 10:15:03 AM »
As Hood says, yes.
A while isMoving will wait until Mach signals VB it can continue, wheras a sleep is VB guessing how long it should wait. A while isMoving with a sleep is a wait until Mach signals with a well mannered nod to the OS that it can ignore the VB thread for a while and save those precious CPU cycles. However of course Mach might signal whilst VB is asleep which wastes precious micro-seconds - its all horses for courses.
Bottom line is... In any asynchronous multi-thread programming setup, there are usually times when you need to synchronise. i.e. wait for the server to be at a known point before continuing with the client.
Waiting on semaphores (the fancy/geek term for all this malarky) is an integral part of multithread comms so at the moment I can't figure out how this can be done away with but Brian clearly has some devious scheme up his sleeve  ;D
Again hope this helps
Ian
Re: G4 versus Sleep
« Reply #12 on: October 06, 2009, 11:12:32 AM »
Here is a script of code that raises the question of when to use G4 versus sleep.
This code works:
   Code "G90"                 ' Set absolute mode
   DoOEMButton (180)     ' Set work coordinate mode on
   Sleep 100
   New_Z = GetDRO(2) + 0.2
   Code "G0 Z" & New_Z
This code does not work regardless of the specified dwell time:
   Code "G90"
   DoOEMButton (180)
   Code "G4 P0.1"
   Code "G0 Z" & New_Z
I have seen the dwell command (Code "G4 P0.1") used many times to delay movement of an axis  immediately after a DRO is changed by code. Should the dwell command (G4) be used or should an equivalent sleep command be used? I am running a SmoothStepper which may be complicating this.
The "Code" function does *not* complete execution of the G-code before returning, so doing a Code "G4 Px" will return immediately, regardless of the dwell time given by the P argument.  The dwell *will* execute correctly between successive lines of G-code.  So, for example:
    Code "G0 X0 Y0"
    Code "G4 P1000"
    Code "G0 X1"
will correctly insert a one second delay between the two rapid moves.  If you want VB to dwell, you must use Sleep.
Re: G4 versus Sleep
« Reply #13 on: October 08, 2009, 12:30:28 PM »
I nkow this sounds like I am asking the same queston, but it is a little different. The zero touch plate probing routine I was modifyig was originally written by someone else. In that code, anytime a DRO was changed they added G4 P0.5 with a comment that said "pause for the DRO to update." Based on the feedback from this thread, I don't think the G4 command was the appropriate one to use, but rather a sleep command should have been used to pause on the VB side. However, rather than have a fixed pause, I'd like to add this code after a DRO is updated:
While IsMoving ()
  sleep 10
Wend
My question is: does "IsMoving" apply to a DRO update? If so, I would think I could add the While IsMoving loop and do things fatser than having a fixed pause.
Thanks for all the help!
Kent
Re: G4 versus Sleep
« Reply #14 on: October 08, 2009, 01:58:51 PM »
While IsMoving ()
  sleep 10
Wend
Kent
Oddly enough, that should work fine.  IsMoving(), rather than indicating that an axis is moving, I believe actually indicates there are remaining commands in the G-code queue.  So, IsMoving() will return 1 any time there is *any* G-code waiting to be executed.  This can be confirmed by running the following as a button script, as I just did:
Message "Startin delay..."
Code "G4 P5000"
While IsMoving()
   Sleep 100
Wend
Message "Delay Done"
You'll see the first message displayed for 5 seconds (more or less...), before the second message is displayed.
Offline stirling
  •  2,188 2,188
  • UK
Re: G4 versus Sleep
« Reply #15 on: October 08, 2009, 02:22:16 PM »
does anyone ever feel they're living in a parallel universe and that maybe they don't actually exist? - I know I do  ;D
Re: G4 versus Sleep
« Reply #16 on: October 08, 2009, 03:17:18 PM »
Can you use IsMoving to see that a DRO has finished updating. I wouldn't call a SetEOMDRO command G-code, so I am wonderig if IsMoving will be a good way to detect that the DRO has finished being upadted.
Re: G4 versus Sleep
« Reply #17 on: October 08, 2009, 04:01:53 PM »
No.  The DROs update when Mach does its ~10X/second update loop.  There is no way to "wait" for that other than with a Sleep.  In Mach3 v4, most of these issues, and many others, will be handled in a FAR more deterministic and regular manner, and it will rarely be necessary to add delays or While loops to your VB code.
Re: G4 versus Sleep
« Reply #18 on: October 08, 2009, 04:13:12 PM »
OK..hopefuly I am about finished asking questions on this. The original code had a G4 P0.5 command after any DRO update. Given all I have learned from that thread, it sounds like that command could not be doing as intended. But then again, I am not sure what the problem was that casued the need for this to be added. Perhaps this is code developed long ago that no longer applies.  It sounds like I should actually use a Sleep 100 (or perhaps add some, say Sleep 120) to make ure that Mach has made it through its 100 msec loop). Do people normaly add a sleep command after any DRO update?
CAN'T WAIT FOR VERSION 4...just hope it plays well with a SmootStepper!
Re: G4 versus Sleep
« Reply #19 on: October 08, 2009, 04:19:38 PM »
You only need to put a delay after a DRO access if you're reading the DRO, and want the modified value.  For example, if you do this:
Code "G0 X0"
SetDRO(123, 456)
Code "G1 X1"
X = GetSRO(123)
You should be fine.  But, if you do:
Code "G0 X0"
SetDRO(123, 456)
X = GetSRO(123)
You will likely find X gets set to the old value of the DRO, unless you insert the delay.  This is something I've never understood, but I've seen it enough times to just be careful.
