Hello
Guest
it is
October 29, 2026, 09:17:04 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Laser/Impact Engraver Plugin
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Laser/Impact Engraver Plugin (Read 9791 times)
bdring
30
on:
October 05, 2009, 03:46:36 PM »
What pin is used to control the laser with the Laser Engraver Plugin. How is it setup?
Logged
Tweakie.CNC
9,375
Super Kitty
Re: Laser/Impact Engraver Plugin
Reply #1 on:
October 09, 2009, 02:54:56 AM »
For others that follow.
Bart has found the answer to his question:-
The ENGRAVING triggering is output on the DIGITAL TRIGGER pin which you will need to assign to a pin and enable.
Logged
Print
Pages:
1
Go Up
« previous
next »
