Hello Guest it is September 30, 2026, 02:49:28 PM
Author Topic: How To Tell When A G-Code Program Is Running?  (Read 24267 times)
Offline Bodini
  •  216 216
Re: How To Tell When A G-Code Program Is Running?
« Reply #10 on: December 19, 2009, 07:46:40 AM »
Son.
Of.
A.
Mofo.
Got any other classified info up your sleeve?  Guess that tidbid outta make it to the wiki.  Thanks, Jason.
/nick
Offline Vogavt
  •  260 260
« Reply #11 on: February 07, 2015, 08:26:18 AM »
I have put together all the references I found on VBS when I was writing macros HERE for download.
Anyone happen to have the VBS_info.zip that is no longer available at the above link?
Would love to take a peek at it.
« Reply #12 on: February 07, 2015, 01:01:09 PM »
There are 3 things to look at to tell IF a Gcode FILE is loaded and running. IT MAY NOT  work IF a macro (M6) is running a tool change
 GetOemLed(172) ----->  IF TRUE then a Gcode is loaded
 GetLED(4)           -----> IF TRUE then CYCLE START is active
 GetLed(5)           -----> IF  TRUE then in FEEDHOLD (pause)
Note there are instances when Mach3 is running a GCODE that you can be in FEEDHOLD and the Cycle start LED will be ON.
AND in some instances whle in Feedhold the LED will be ON. IT just depends on what  Mach3 is doing when you FEEDHOLD.
So you have to account for that as well.
« Last Edit: February 07, 2015, 01:03:00 PM by BR549 »
« Reply #13 on: February 07, 2015, 01:24:08 PM »
UPDATE (;-)
Further Testing, Looks like
GetLed(172)
GetLed(4)
Will do the JOB. BUT you MAY be able to only use
GetLed(4)  ----> Cycle Start
