Hello Guest it is October 02, 2026, 02:23:14 PM
Author Topic: Tool change position  (Read 13250 times)
« on: August 26, 2009, 04:56:44 PM »
I know this subject must have come up once or twice.
Can anyone help me or explain how to set up tool change location in Mach.
THX
Thomas
Thank you for your support in developing better cnc experiance.
 Scan my avatar with smart pnone .......
http://big-tex.tk/
Re: Tool change position
« Reply #1 on: August 26, 2009, 04:59:02 PM »
What exactly are you looking for? Are  you are wanting to have it called from G Code or a button on the screen?
« Reply #2 on: August 28, 2009, 10:26:44 AM »
When G code calls for tool change, I would like machine to go in designated tool change position using machine coordinates.
For arguments sake lets say x48.0 y0.0 z3.5
In my general config I use setting "AutoTool Change" and I do my tool changing manually.
Just to give you more info I use blue screen and in settings screen within section tool change location I have designated already the above listed location.
Thomas
http://big-tex.tk/
« Reply #3 on: August 28, 2009, 12:26:49 PM »
I am not sure what will be in your M6Start.m1s macro but if you add
Code("G53G0X48Y0Z3.5")
While IsMoving()
Sleep 100
Wend
at the start of the code it should go to that position first before it does anything else.
You may want the Z to retract first, if  so it would be
Code("G53G0Z3.5")
While IsMoving()
Sleep 100
Wend
Code("G53G0X48Y0")
While IsMoving()
Sleep 100
Wend
that you would put in the macro.
Just be careful though the first time you try it.
« Reply #4 on: August 28, 2009, 12:29:20 PM »
I will give it a try. THX
Thomas
http://big-tex.tk/
