Hello Guest it is October 20, 2026, 09:43:41 PM
Author Topic: Go To Zero  (Read 28092 times)
Re: Go To Zero
« Reply #10 on: August 26, 2009, 03:15:14 AM »
I am using Mach 3 standard screen, regarding Dave's post if you use a mill in semi manual mode i.e. making a couple of cuts, rather than writing lots a G code GoTo Zero is usefull especialy when setting the job up.
Mike
Re: Go To Zero
« Reply #11 on: August 26, 2009, 03:32:05 AM »
please attach your xml
Re: Go To Zero
« Reply #12 on: August 26, 2009, 07:33:47 AM »
xml as rquested
Re: Go To Zero
« Reply #13 on: August 26, 2009, 07:43:48 AM »
xml looks fine apart from your kernel speed is set to 25KHz and your motor tuning requires more so probably best to either change the velocity or change to 45KHz kernel, the latter probably the preferred.
Go to the operator menu and choose Edit Button Script and you should see the Ref All button flashing, click on it and copy the info in there and post here.
Re: Go To Zero
« Reply #14 on: August 26, 2009, 10:54:36 AM »
Here is info you requested
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Where do I find kernal speed box? looked in general settings
Mike
Re: Go To Zero
« Reply #15 on: August 26, 2009, 11:05:47 AM »
Ports and Pins main page for the kernel.
Your button code is fine so thats not the problem.
Re: Go To Zero
« Reply #16 on: August 27, 2009, 02:47:18 AM »
Thanks for fix, all is well
Mike
Re: Go To Zero
« Reply #17 on: August 27, 2009, 08:14:08 AM »
Good to hear it, wasnt sure if that would cause your issues or not, the normal problem with that is rapid moves would be jerky I think.
