Hello Guest it is September 29, 2026, 06:04:45 PM
Author Topic: 5vdc source  (Read 10590 times)
5vdc source
« on: August 24, 2009, 09:32:21 AM »
I know this has probably been brought up before, but do I use a 5 vdc source from my PC power supply to activate things like relays, pulse +/-, enable +/- , dir +/- , limit switches, etc, or do I need to use a separate power supply for this? I have 1 on order just in case. Will there be a conflict with the + or ground with the PC ? I'm ready to wire, but I don't want to burn anything up. :-[.
Any help with this would be greatly appreciated as the deadline on this project is drawing nearer.
Keith
Re: 5vdc source
« Reply #1 on: August 24, 2009, 11:36:03 AM »
Best to use a separate supply, and just tie the grounds together.
Re: 5vdc source
« Reply #2 on: August 26, 2009, 01:25:17 AM »
I normally use the 5 and 12 V from the PC power supply. If you take all needed care it should not be any problems, and sometimes it is very handy.
But separated power is always better.
