Hello Guest it is November 22, 2026, 07:04:05 AM
Author Topic: Wizard for editing a ready tap file.  (Read 24263 times)
Re: Wizard for editing a ready tap file.
« Reply #10 on: August 26, 2009, 12:25:22 AM »
What is tool comp?
vmax549
« Reply #11 on: August 26, 2009, 09:56:34 AM »
It is an offset function of CNC machines that let you use a centerline drawing to program with THEN the machine can do the offsetting to account for TOOL  radius. Instead of the CAM apply offsets the machine does instead. THat way YOU can adjust the amount of offset needed to create an accurate part.
Hope that helps(;-) TP
