Hello Guest it is October 20, 2026, 08:46:50 PM
Author Topic: bob cad with mach 3 question  (Read 24932 times)
Re: bob cad with mach 3 question
« Reply #10 on: August 23, 2009, 01:21:46 PM »
yes i posted on the cnc zone forum ,no answer. i will call support in the morning.
thanks alex
Offline Toad
  •  58 58
« Reply #11 on: August 23, 2009, 03:30:07 PM »
If it helps, when i ask a similar question to BobCad, this is the answer I received:
The translate w/ a scale doesn't work on bobART surfaces, but if you go back to the BobART tree and edit the stock first and set that to the new size, then edit the emboss item in the tree to the same size, you can right click on Emboss Model and choose "Regenerate", which should rebuild it to the new size.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #12 on: August 23, 2009, 03:56:21 PM »
Hi, Alex
Been a little tied up hear, I haven't used the posting code much in bobcad 23, I think it's just leaving off the return for X in the Post.
Look at this G code and post an example of your G code & dxf.
Chip
