Hello Guest it is November 25, 2026, 11:33:06 PM
Author Topic: Smooth Stepper reset  (Read 44263 times)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Smooth Stepper reset
« Reply #20 on: August 23, 2009, 01:14:47 PM »
The one they sell is 6'. I have them in 10' and 15' as well. Shorter is better. VFDs are noisy critters though, the USB isolator Greg is working on may be a good fit in your application.
Happy machining , Jeff Birt
Offline Greolt
  •  956 956
« Reply #21 on: August 23, 2009, 05:20:39 PM »
OK I take it that no one knows what the reset on the SS does or how to implement it.   ;D
Greg
« Reply #22 on: August 23, 2009, 05:33:41 PM »
Greg
It has been answered at least twice in this thread, or are you meaning something different?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #23 on: August 23, 2009, 05:34:36 PM »
Well, I have already stated twice what it does, what the heck maybe the third time is the charm...It clears the flash memory. You have to have the jumper in place when the SS is powered up. It is something you will most likely never need to do.
Offline Greolt
  •  956 956
« Reply #24 on: August 23, 2009, 05:46:55 PM »
Well I must apologise.  :-[
"Clears the flash memory"    I guess I did not understand what that meant.
I was under the impression that the plugin in Mach reset the flash memory every time Mach booted up.
Greg
EDIT:  I reread Jeff's post number ten where he explained that.  First reading I was just seeing talk of noise elimination discussion and skipped over that bit.  Sorry.
« Last Edit: August 23, 2009, 05:50:54 PM by Greolt »
