Hello Guest it is November 27, 2026, 03:07:11 AM
Author Topic: New Project for the shop.  (Read 159119 times)
Re: New Project for the shop.
« Reply #90 on: August 21, 2011, 07:56:02 AM »
Dave, can you tell me where you got the flexible brush for the dust shoe?
« Reply #91 on: August 21, 2011, 08:01:30 AM »
Thanks all, I appreciate the comments.
As for the axis setup, aren't jobs supposed to come out backwards/mirrored?  :D  Yep, ya got me, I actually screwed up when setting up Mach 3 as I'm used to a mill and got my directions reversed. I suppose I should fix them soon so I don't get used to it being backwards. :D
"Ya Nvr No" Those were drawn up in V Carve Pro.
« Reply #92 on: August 21, 2011, 08:03:04 AM »
Hi Gerry,
It's from Mcmaster: 74405T304 Galvanized Steel-Backed Nylon Conveyor Strip Brush, 1/8" W X 1/8" H Backing, 2" H X 4' L Each $17.16
  •  9,379 9,379
« Reply #93 on: August 21, 2011, 08:08:05 AM »
 ;D Suppose you could always turn the "X axis label" upside down and fit the "Y axis label" on the other side of the gantry  ;D
« Reply #94 on: August 21, 2011, 08:15:05 AM »
Better?  ;D
« Last Edit: August 21, 2011, 08:20:43 AM by budman68 »
« Reply #95 on: August 21, 2011, 08:15:39 AM »
Hi Gerry,
Thanks.
How'd you bend it? I'm working on a shoe design for my next machine, and I was thinking of using the next larger size up from yours, and bending it between hardwood block to "form" it.
As for your X and Y axis directions. They're the same as my router. But, I stand on the other side of mine. ;)
« Reply #96 on: August 21, 2011, 08:18:32 AM »
Gerry, it was bent with set of linesman and neednose pliers and "pressed" into a .135 slot. Worked beautifully.
« Reply #97 on: August 21, 2011, 09:35:32 AM »
Thats one nice looking setup but definitely too tidy ;D
« Reply #98 on: August 21, 2011, 10:26:54 AM »
All better now  :)
And also one for the poster fans....
« Reply #99 on: August 21, 2011, 10:28:45 AM »
Ah, give it time, remember when these were clean and new?  :D
« Last Edit: August 21, 2011, 06:17:29 PM by budman68 »
