Hello Guest it is September 08, 2026, 10:45:08 PM
Author Topic: I searched the forums and still can't get the motors to turn  (Read 39674 times)
Re: I searched the forums and still can't get the motors to turn
« Reply #10 on: August 07, 2009, 09:04:28 PM »
On the diagnostics page, on the left side of the page, there is a column of led's with Ref x, Ref y and so on to Ref c. All of those led are red.
Also on the right center in the Port 1 Pins current state, only the 4,5,6,7and 8 led's are green. No other led's are lit.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: August 10, 2009, 10:58:52 AM »
Hi, Dave
Sent you a PM message, Hears a pic with the info.
Chip
« Reply #12 on: August 10, 2009, 11:18:00 AM »
I have it. I hope this helps. Also I have a copy of mach v.020 I'm going to try.
« Reply #13 on: August 11, 2009, 12:04:53 PM »
Well I tried a different computer, the only thing that changed is that I have more port pins on the dia. page light up. Blended spd. is working, but the motors still don't move at all, the dro's move just the motors don't.
I went back and loaded the unmolested g540b xml form Gecko. Nothing.
I'll try almost anything at this point.
Anybody!
Offline Chip
  •  2,055 2,055
« Reply #14 on: August 11, 2009, 02:05:35 PM »
Hi, Dave
On the Diagnostics page do you have a Pulse Frequency showing.
Try this xml file below, I think I got all your settings correct and enabled Sherline 1/2 step mode also.
Chip
« Reply #15 on: August 11, 2009, 08:07:24 PM »
Thanks Chip
I installed the printer port monitor and ran mach again and used your xml file. The printer port monitor says that everything should be working, but it still is not.
I checked continuity pin to pin on the parallel cable and only found 1 pin that was connected  on both ends. So I got my trusty printer cable and all the pins had continuity through out. I guess I need an adapter from female printer ( 32 or 36 pin ) to db25 male. I live about 100 miles form Fry's, but as luck would have it, I'm going right by there tomorrow. I'll see what I can come up with.
Thanks again
Offline Chip
  •  2,055 2,055
« Reply #16 on: August 11, 2009, 09:43:06 PM »
Hi, Dave
Sounds like you have a 25 pin serial cable, What you need is a straight through printer "extender" cable, 1-1, 2-2, 3-3 ...25-25, Some cables omit some of the 18 - 25  Gnd. wires, But this shouldn't be a Issue, Gecko is probably smart enough to have them all tied together in there box.
Thy come in two versions, 25 pin M / F and F / F connector's, The F / F you'll need a gender changer M / M adapter.
Chip
« Last Edit: August 11, 2009, 09:47:50 PM by Chip »
« Reply #17 on: August 14, 2009, 05:41:07 PM »
Many thanks to you guys
I have the motors turning now ;D ;D ;D
Now all I have to do is read the manual and see where to make the direction of the slave "A" motor turn opposite of the "X" motor. I can change the direction of the motors but haven't been able to "slave" them yet.
« Reply #18 on: August 14, 2009, 08:48:58 PM »
I found it.
I loaded the roadrunner file and everything works like it should.
Thanks for the help.
Offline Chip
  •  2,055 2,055
« Reply #19 on: August 14, 2009, 09:16:33 PM »
Hi, Dave
We can almost hear it running hear.
Chip
