Hello Guest it is October 21, 2026, 05:39:26 PM
Author Topic: Problems with display mode  (Read 35089 times)
Re: Problems with display mode
« Reply #10 on: August 05, 2009, 12:43:38 PM »
Its not done it for a while, you need to regen now. I have however added
DoOemButton (160)
at the end of the VB in the button and it now regen's automatically.
« Last Edit: August 05, 2009, 12:57:27 PM by Hood »
Offline sn96
  •  60 60
« Reply #11 on: August 05, 2009, 01:17:49 PM »
DoOemButton (160)
Thanks for the help!
Mike
________________________________
PM25mv with Arizona cnc conversion kit
windows 10
i7 laptop
mach3 demo latest version
stepperonline 566 ozin closed loop stepper 4.0 driver for x and y
stepperonline 1699 ozin closed loop stepper 4.0 driver for the z
amazon no name brand usb controller
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #12 on: August 05, 2009, 02:16:37 PM »
Hi, Mike
I added the do-button as Hood suggested and see what you were talking about clearer now.
Thanks, Hood.  :D
Chip
« Reply #13 on: January 28, 2011, 04:15:49 PM »
Newbie here.
I use a track ball so I don't have a 3rd wheel to zoom. Wondered why my screen want like the video.
So where/how do you add "DoOemButton (160) at the end of the VB in the button and it now regen's automatically."
As I assume this is meaning the Regin Toolpath button?
« Reply #14 on: January 28, 2011, 04:25:56 PM »
You add the DoOemButton (160) to the end of the code in the Display button. What that does is basically the VB in the button will first change the display to Table or Work views and then lastly it will activate the Regen Toolpath button so that you dont need to.
To edit the button you go to Operator menu then Edit Button Scripts and then the Display button should be flashing, click on it and the editor will open allowing you to add the code and then click File and Save then exit the editor.
« Reply #15 on: January 28, 2011, 05:40:04 PM »
Sweet
Tx so much for the info, fix, and speedy reply.
