Hello Guest it is November 22, 2026, 10:05:51 AM
Author Topic: 25 Pin Parallel Signal Tester with LED's for each pin WANTED  (Read 25725 times)
Re: 25 Pin Parallel Signal Tester with LED's for each pin WANTED
« Reply #10 on: August 04, 2009, 08:29:52 PM »
Sorry Hood... On the CW CCW I meant how does it look different than a G01 (line). Does a CW CCW pulse use a different parallel port pin? I have a really old system I am having to reverse engineer. No real good schematics.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: August 04, 2009, 09:26:29 PM »
Hi, Steve
Direction is controlled with the dir. pin being ether held high or low on each axis then the step pin is pulsed to move the axis the desired amount.
3 axises 6 pins and common Ground.
Chip
« Reply #12 on: August 05, 2009, 06:56:55 AM »
I have 2 parallel ports. How do you read both? I guess 1 at a time?
Note that I said ONE OF my BOBs. I also have one of Peter Homann's new BOBs, but it does not have LEDs . . . . consequently it is very small . . . so advantages are traded.  For two ports, you need two BOBs.
One exception I am aware of is a product called 'smooth stepper'. There is a section on this forum dedicated to the product. I don't know much about it, but apparently (among other advantages) it replaces two parallel ports with a USB connection.
