Hello Guest it is November 13, 2026, 12:17:53 AM
Author Topic: Converting Step and Direction signal to CW/CCW  (Read 28902 times)
« on: July 29, 2009, 07:00:53 PM »
How to converting Step and direction signal to CW/CCW signal. My drive input is CW/CCW signal and mach3 output is Step/Dir.
Is there any CMOS/TTL ic converting step/dir to CW/CCW?
i can do with uController but i'm looking for simple IC in CMOS or TTL level
Please Help
regards
Ardoan, Indonesia
Re: Converting Step and Direction signal to CW/CCW
« Reply #1 on: July 29, 2009, 07:19:41 PM »
Go to Config->Ports&Pins->SpindleSetup.  In the top-left corner, you can define a CW output pin and a CCW output pin.
« Reply #2 on: July 29, 2009, 08:36:28 PM »
See the attached. It should be what you are after.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
« Reply #3 on: August 01, 2009, 10:07:13 AM »
Thanks Peter, it's work well, now i am trying converting the signal to 24 volt for input to servo which speed is enough up to 200Khz (safety factor 4x)
« Reply #4 on: August 02, 2009, 12:06:13 AM »
Good to hear. What are the specs for the input to your sevo drives? Are they opto diode inputs? what current is required?
Cheers,
Pewter
Homann Designs
« Reply #5 on: August 02, 2009, 05:44:48 AM »
Servo is Fuji Faldic 750Watt, input is optoisolated, 40mA max needed.
« Reply #6 on: February 17, 2013, 03:04:41 PM »
Cheers,
Peter.
Hello
I know this is an old topic but maybe it is someone that can help me. I need to convert Step and Direction signal to CW/CCW too but i don't understend this schematic (what ar thoes 2 cip's from the picture) :D
Thank you!!!
